Results 1 to 10 of 17
Thread: Annotation Scale list keeps propagating the whole list
    Member jacep's Avatar
    2006-03
    33
    Default Annotation Scale list keeps propagating the whole list
    We are working on getting our standards and blocks updated / converted for the leap to vanilla ACAD 08. I tried to read up on all the annotative scale issues and converting DB to include annotative scaling.
    So here’s what I cant figure out: I created a new fp proto dwg and removed all of the scales I do not want in the dwg. I revamped some of the details (door tags, room tags…) to be annotative and removed the scales I do not want in the dwg. I still get that long list of annotative scales.
    What am I doing wrong, cuz I know it is not AutoCAD.....................
    Jace Paddleford
    Architect
    Bockus Payne Associates Architects
    plain ol' Acad 2k6, 2k8, 2k9, customized for my pleasure.
    Architecture 2k9 someday.............................................
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Default Re: Annotation Scale list keeps propagating the whole list
    Be sure your are "purging" the unneeded scales in your blocks too. If a block has an Annotative Scale within it, it will import that scale when inserted into your drawing.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
    2006-03
    33
    CADDmanVA - I will go back and triple check that the scales were purged out. I know they were removed from the list, but purged huh.
    Thanks foe the idea
    Jace Paddleford
    Architect
    2006-12
    New Orleans, LA
    881
    Quote Originally Posted by jacep View Post
    Thanks foe the idea
    Sorry, maybe the phrase purge was a bad idea to use. You can't delete Annotative Scales from the PURGE routine. That's just the first thing I would check on, I still have that problem with some of my older blocks.
    I could stop if I wanted to ededios's Avatar
    2015-12
    Los Angeles, CA
    211
    Unhappy Re: Annotation Scale list keeps propagating the whole list
    Quote Originally Posted by CADDmanVA View Post
    Hello!
    What I did was take the list of scales I don'need out of my template file. Then I made sure my blocks didn't have the long list either.
    So I created a new file, checked the list it, and it was fine, then I inserted a block, and the list is now back to default. Is that normal? I hope not.
    Elisa de Dios
    Job Captain / BIM Manager
    AC Martin Partners
    follow me on Twitter
    a beginner revit blog
    2006-12
    New Orleans, LA
    881
    Quote Originally Posted by ededios View Post
    ...So I created a new file, checked the list it, and it was fine, then I inserted a block, and the list is now back to default. Is that normal? I hope not.
    No, that is not normal at all. Is it possible you can post the template and offending block?
    2006-03
    33
    What I have found is that if I insert the cleaned out blocks and insert them into the new template, then the scale lists as they should be, only the scales I want, but if I pull the block off a pallet then the scale list has everything.
    Jace Paddleford
    Architect
    2015-12
    Los Angeles, CA
    211
    That's exactly my problem, also inserting from Design Center has the same effect.
    Using the insert command works fine, but all our standard blocks come from Tool Palettes. So I hope there's something I can do to fix this.
    CADDmanVA - I've attached my template and a file that has some standard blocks (where my Tool Palettes grab the blocks from).
    Thank you
    Elisa de Dios
    AC Martin Partners
    2006-12
    New Orleans, LA
    881
    That explains a lot. Annotative Scale doesn't get along well with the DC and pallets. I don't use either, so it never occurred to me before you two mentioned it. Sorry about that.
    2015-12
    Los Angeles, CA
    211
    It's this kind of stuff that makes me miss Microstation
    Well, I can now leave this topic and move on to the next. . Thank you CADDmanVA!!
    Elisa de Dios
    AC Martin Partners
  1. Replies: 9
    Last Post: 2010-11-25, 11:03 AM
  2. annotation scale list
    By kmf2797 in forum AMEP General
    Last Post: 2008-08-21, 03:12 PM
  3. Replies: 6
    Last Post: 2007-05-24, 08:44 PM
  4. AutoCAD 2008 Delete scale from Annotation Scale list
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2007-04-25, 02:21 PM
  5. Accessing the annotation scale list in AutoCAD 2008
    Last Post: 2007-04-24, 08:28 PM
