Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Annotation Scale list keeps propagating the whole list
  1. #11
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Default Re: Annotation Scale list keeps propagating the whole list
    Quote Originally Posted by ededios View Post
    It's this kind of stuff that makes me miss Microstation
    Well, I can now leave this topic and move on to the next. . Thank you CADDmanVA!!
    You're welcome. Sure, Autodesk pulled a dummy with this one, but come on! Bentley finally got a clue and gave users more than a handful of levels...still no ability to give them names though...
  2. #12
    2015-12
    Los Angeles, CA
    211
    LOL . . .When they opened up the possibilty of having a million levels, they also allowed them to be named, the numbers only remain for legacy purposes.
    My issue is there seems to be no follow through to make sure new features work with other things as they should. Bentley would've made sure it worked on the palettes and design center because it's obvious. . . as they did when they allowed a million levels to be created, it was obvious naming them should be the default vs. keeping them numbered and then allowing names in the next release. . . follow through
    But I've moved away from it and I'm learning to accept Autocad again, I can't help but miss it.. . . until I get everyone using Revit!!!
    Thanks again
  3. #13
    2006-12
    New Orleans, LA
    881
    Ha ha, you have a good point there. Autodesk has been known to pull a few stupid moves in the past. I cut my teeth on AutoCAD almost 10 years ago. When I had to use Microstation (V5 I think), it didn't mesh well with the experience I had up until then. To each there own though...ambiguity makes the world go `round
  4. #14
    2006-03
    33
    Quote Originally Posted by CADDmanVA View Post
    Annotative Scale doesn't get along well with the DC and pallets.
    Thanks CADDmanVA. That is what I am figuring out.
  5. #15
    2015-12
    Los Angeles, CA
    211
    Thanks again CADDManVA.
    Hopefully there's a fix for this soon.
  6. #16
    2006-03
    33
    I am working on a workaround. Don't know if it will work just yet. I will let you know if anything works out.
  7. #17
    2015-12
    Los Angeles, CA
    211
    Quote Originally Posted by jacep View Post
    Great thanks! I was looking through Autodesk Discussion groups, someone mentioned doing a VBA routine as a "band-aid" as the person put it, but didn't specify how. I haven't gotten into that yet, not sure if that's where you were headed. Here's the link http://discussion.autodesk.com/threa...sageID=5569418
  1. Replies: 10
    Last Post: 2022-08-25, 10:06 PM
  2. annotation scale list
    By kmf2797 in forum AMEP General
    Last Post: 2008-08-21, 03:12 PM
  3. Replies: 6
    Last Post: 2007-05-24, 08:44 PM
  4. AutoCAD 2008 Delete scale from Annotation Scale list
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2007-04-25, 02:21 PM
  5. Accessing the annotation scale list in AutoCAD 2008
    Last Post: 2007-04-24, 08:28 PM
