Results 1 to 10 of 10
Thread: Standard Checker Issue
    Blue Springs, MO
    658
    Default Standard Checker Issue
    I have a dimstyle ( a few actually ) where all the line work is 'bylayer' and the text is set to a specific color. My problem is when I run the standards checker, the text in all my dimensions change color to match the linework. Strange thing is when you check the dimstyle, it's set correctly. The only way I've found to get it to display correctly is to open the dimstyle manager, pick the dimstyle, click 'modify' then hit ok. I don't even have to change anything but just by opening up the dimstyle and closing it make the dimensions display properly. Has anyone else run into this? Is there something I'm doing wrong?
    Blue Springs, MO
    658
    Default Re: Standard Checker Issue
    UPDATE:
    I've narrowed it down a little more. I'm not having problems with the standards checker. My problem occurs after running the layer translator.
    Any ideas?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,131
    Quote Originally Posted by jmctamney View Post
    UPDATE:
    Any ideas?
    Check your settings in the Layer Translator dialog. Uncheck the force color to ByLayer.
    Blue Springs, MO
    658
    That was it. I actually figured it out just before lunch. It's amazing how things come to you once you step away from it for a minute or two. What I still don't understand is how it can change the text color to 'bylayer' but the dimstyle still has the color set to white (in this example). I think I'll add it to my list of AutoCAD "features" I don't understand.
    2007-06
    271
    It's because when you set a text color, you're changing the layer color of just the text object. So when you tell it to force color by layer, it changes the text's color to that of the layer your dim is set to.
    One of those things I wish we could fix without exploding...
    Blue Springs, MO
    658
    That makes sense but the part that gets me is that it doesn't change the color in the dimstyle. If it is indeed setting everything to bylayer one would think the color in the dimstyle would be change to bylayer as well.
    2007-06
    271
    It changes the objects to Bylayer, so the styles will remain the same, but the objects' styles get overridden by the object's layer color.
    I really don't like it either, makes my job so much harder.
    What I want to know is, why don't they allow you to set a LAYER for your text, and only allow you to set a color? You're allowed to do it for different parts of surfaces and alignments, why not leaders with text?
    2002-01
    jUSt Here (a lot)
    9,131
    Because surfaces and alignments are not native vanilla AutoCAD entities.
    Blue Springs, MO
    658
    Quote Originally Posted by Harold Pei Jr View Post
    Sounds like a wish list item!!
    2007-06
    271
    But I believe dimensions are.
  1. Standard Issue...
    By nightNday in forum CAD Standards
    Last Post: 2008-02-19, 03:23 PM
  2. Error obtaining plugin for Standard Checker
    By Jack Cheong in forum CAD Standards
    Last Post: 2008-01-03, 12:15 PM
  3. Replies: 2
    Last Post: 2006-04-28, 11:17 AM
  4. Titleblock - issue date and type of issue placed in issue column
    By jdrexler in forum CAD Management - General
    Last Post: 2006-04-10, 05:01 PM
  5. BUG in the standards checker?
    By Spectrefish in forum AutoCAD General
    Last Post: 2005-06-16, 07:05 PM
