Thread: Autocad 2008 Mtext Word formate
    2005-12
    2
    Default Autocad 2008 Mtext Word formate
    Creating a single spec sheet from a word doc takes a very long time due to the fact I have to reformat tabns etc.. I copy and paste into mtext. Havent used colums yet. Where can i go to lean the best way of bringing in a word doucment into mtext. A link would be nice but not if i need to OLE. Thanks in advance.
    2007-08
    Central California
    38
    Default Re: Autocad 2008 Mtext Word formate
    do a ctrl+c on the word doc then open autocad and then start the mtext. In the mtext box do your ctrl+v. this seems to be the easiest I have found. Good luck.
    2005-12
    2
    Thanks, However i still loose indents and tabs. Perhaps its the set up in the word document that's throwing me off
  1. WORD WRAP IN MTEXT
    By clintonc in forum AutoLISP
    Last Post: 2011-09-16, 04:08 PM
  2. MTEXT formatting from Word to AutoCAD
    By concrete141 in forum AutoCAD Annotation
    Last Post: 2007-09-27, 04:01 PM
  3. Replies: 3
    Last Post: 2007-09-07, 04:36 PM
  4. AutoCAD 2008 MText indent lost when opening in AutoCAD 2007
    By nbowley in forum AutoCAD Annotation
    Last Post: 2007-09-07, 04:35 PM
  5. Export MText into Microsoft Word
    By gcameron in forum AutoCAD General
    Last Post: 2006-06-01, 05:01 PM
