View Poll Results: Projects with multiple buildings
Voters
8. You may not vote on this poll
  • Yes I definitely need this
    6 75.00%
  • This would be useful
    2 25.00%
  • Nice idea, but I would not use it
    0 0%
  • No, this is not needed, please work on another features
    0 0%
Thread: Projects with multiple buildings
    2004-07
    96
    Default Projects with multiple buildings
    Description: Projects with multiple buildings
    How Used: We produce large projects which have usually about 10 buildings on them – the navigator does not easily cater for this.
    The project navigator will cater for this if you type the levels in like this
    Building 01 – Ground Floor +0000
    Building 01 – First Floor +3000
    Building 02 – Ground Floor +0000
    Building 03 – Ground Floor +0000
    Building 03 – First Floor +2700
    But it keeps an error “The value entered is invalid” when you type a level which matches the level of another building. The work around is to keep typing the level and about the third time, for some unknown reason, it accepts the value.
    We have successfully produced a project with multiple buildings in one project - but the errors from PN and the lack of clarity which many levels are display make the project difficult to work with.
    Feature Affinity: Project Navigator
    2002-09
    Madison, WI
    5,687
    Default Re: Projects with multiple buildings
    Have you looked at using divisions for each building. ie each building is it's own division?
    Just a thought.
    2004-07
    96
    Quote Originally Posted by david_peterson View Post
    Just a thought.
    I tried this - the problem is that you cannot set a level for each division.
    So divisions would work OK if all buildings has the same set of levels.
    Really I think this could be an easy win for AutoDesk - it seems to almost do what's required - all they need to do is turn off the annoying error message and provide some means of grouping the levels into buildings instead of a large unmanageable list.
  1. 2014: Multiple Buildings/ Multiple Construction Docs/ Shared Details
    By tmiller682525 in forum Revit Architecture - General
    Last Post: 2014-11-05, 01:35 PM
  2. Recommendations on projects with multiple buildings?
    By kmarshall in forum Revit Structure - General
    Last Post: 2009-04-01, 12:48 PM
  3. Multiple Buildings
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2008-09-10, 02:38 AM
  4. Linked Projects - Scheduling of Doors for Different Buildings
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2008-06-17, 12:30 AM
  5. Multiple Buildings
    By mmaxwell in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-10-19, 02:31 AM
