Thread: Problem starting VIZ 2008 in Vista
    2007-11
    6
    Exclamation Problem starting VIZ 2008 in Vista
    Hi there,
    I'm running Windows Vista Ultimate 64-bit on my system and i've just installed this VIZ program. Problem is that when itry and run it, either the initial loading screen pops up for a second then disappears, or it pops-up and on loading the mentalray.dlz file just hangs there and crashes.
    Has anyone had this problem before? If so, is there a way around it?
    I've tried removing windows Aero visualisation, running the program in administrator mode and even put the compatability into XP SP2, but i still have the same problem.
    Any help will be hugely appreciated... i really want to do proper renders!
    2008-01
    Default Re: Problem starting VIZ 2008 in Vista
    Hai
    I also having same problem Please any one do needful.
    Thanks
    Anandh S
  1. Problem Inventor 2008 mit Vista SP1 behoben?
    By tofast4you_02 in forum Deutsch - Inventor
    Last Post: 2008-08-06, 07:58 AM
  2. Error message when starting Acad 2008
    By drafting.82475 in forum AutoCAD Customization
    Last Post: 2008-03-27, 09:09 AM
  3. INV 2008 und Vista
    By akaiser in forum Deutsch - Inventor
    Last Post: 2007-11-08, 03:43 AM
  4. Map 3D 2008 on Vista 64 bit?
    By kiku in forum AutoCAD Map 3D - General
    Last Post: 2007-07-05, 08:36 AM
