Results 1 to 6 of 6
Thread: Apply Edit History (NOT APPLYING)
    2006-04
    5
    Default Apply Edit History (NOT APPLYING)
    Using LDT 2007
    I went into terrain model surface and created a new surface. Then I added all the points needed for my surface. I built the surface with apply edit history checked. Imported the 3D lines and created my contours. I fliped the tins around as I needed to and saved my surface then closed out. The next time I opened the drawing and made the surface current I found that the surface seemed to be dead meaning I couldn't flip the tin lines around.
    I find that its very frustrating not being able to use a surface without redoing the entire surface 2 or 3 times. If its adding a point with a point group or adding points one by one it doesn't take my applied edit history into account. All the settling and paths seem to be correct.
    If anyone has had this problem before and has a solution your help would be greatly appreciated. Thanks
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,013
    Default Re: Apply Edit History (NOT APPLYING)
    This will be no help but we have never trusted the edit history. The only surface edits allowed at my company are delete lines to trim the boundary of the surface. And even then we would import the surface boundary as a 2D poly and define it as the boundary when we were done trimming so we would not have to trim it again. If we needed to flip a TIN line we would draw a 3D poly through the points and add that to the surface definition. Every surface (major ones at least) would have it's own drawing that contained only the data used to build the surface.
    I look forward to the day when the whole company is using Civil 3D for surfaces. It is much easier to create, edit and manage surfaces in Civil 3D.
    Jeff Paulsen
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    This problem is documented in the Knowledge Base.
    http://usa.autodesk.com/adsk/servlet...linkID=9240777
    2002-04
    Colorado
    2,013
    Wow that is ridiculous. I guess we never noticed because luckily we never relied on the Edit History anyway.
    Jeff Paulsen
    2015-10
    I agree, rediculous. I don't think the Autodesk solution qualifies as a solution, but more as a workaround. Would be nice if it actually applied the edit history as the checkbox implies.
    Member DB4-LYF's Avatar
    2008-02
    Springfield, Missouri
    20
    I always right click on the surface Im working on and save, after I delete lines and make sure the surface is correct.
  1. Applying tapered thread gives option to also apply taper
    Last Post: 2012-02-08, 02:12 PM
  2. apply command does not apply in "edit rail"
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-12-16, 06:21 PM
  3. Apply Edit History :o(
    By awiebe in forum Land Desktop - General
    Last Post: 2006-06-22, 10:29 PM
  4. Contour Edit History
    By sbullinger in forum Land Desktop - General
    Last Post: 2005-10-24, 04:21 PM
  5. Edit Surface not applying edit history
    By EngME in forum Land Desktop - General
    Last Post: 2005-01-18, 09:26 PM
