Results 1 to 1 of 1
Thread: Raster Clipping problem
    2006-01
    9
    Default Raster Clipping problem
    Please help!
    In dwg I have rasters and points.
    I need to clip each raster. The source for clipping boundary will be points.
    Problem is that raster do not clip and moves to zero showing nothing.
    When I use same coordinate for doing PLine, PLine is OK!
    Hope someone will find what I'm doing wrong.
    att: dvb and sample dwg with raster and points.
  1. 2014: Far Clipping problem
    By wing_yee in forum Revit Architecture - General
    Last Post: 2014-01-17, 04:39 PM
  2. Clipping FDO Referenced raster images
    By coondog45 in forum AutoCAD Map 3D - General
    Last Post: 2011-08-23, 02:45 AM
  3. Raster problem with Osnap on/off shortcut
    By mdharrisUK in forum Raster Design - General
    Last Post: 2010-03-20, 11:40 PM
  4. Still Render VS Animation Clipping Problem
    By cek in forum Revit - Rendering
    Last Post: 2010-03-05, 08:41 PM
  5. Raster Insertion Problem
    By dabbott in forum AutoCAD Map 3D - General
    Last Post: 2007-11-14, 05:19 PM
