Results 1 to 6 of 6
Thread: Stair - extend baluster feet to tread?
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    Default Stair - extend baluster feet to tread?
    Would anyone know if it is possible within the railing editor (or other method) to make the balusters extend to the treads when no string is present, as in the attached spiral stair?
    2006-06
    Toronto, ON
    2,386
    Default Re: Stair - extend baluster feet to tread?
    Well, if you are working with worksets, you could try to make the strings open to have the balusters matching the treads level and just put it into another workset (onte that's always off).
    It should work.
    Regards,
    Andre Carvalho
    2006-06
    Toronto, ON
    2,386
    Ops, ignore what I've said...
    Differently from stair railings, strings are part of the stair and can't be on a different workset...
    Sorry about that.
    But what about making them 100% transparent?
    Andre Carvalho
    2006-06
    Toronto, ON
    2,386
    Ok, better than this yet, is to edit the baluster family and get rid of the bottom void (the one that is defining the baluster to be cutted at the stringer level).
    Then just lock the base of the baluster with the reference level and it definitelly will work. Just make sure your railing is inside the stair boundary.
    See attached.
    Andre Carvalho
    Last edited by Andre Carvalho; 2007-12-18 at 06:52 PM. Reason: Couldn't get the JPG uploaded properly
    1,222
    Many thanks for your perseverance Andre
    I will try what you suggest.
    Also I have just looked this up in the new Mastering Revit 2008 book, and on page 386 it illustrates spiral stairs with two or one baluster per tread and no strings, and the balusters sit perfectly on the treads.
    cheers
    1,222
    You gave me the vital clue in the last sentence Andre
    It works with any baluster, you do not need to edit them (although that was an interesting exercise in itself, thanks)...
    just as long as you select the handrail and then click the 'flip' arrows so that the handrail is within the stair boundary.
    Then the balusters will sit on each tread.
    thanks again
  1. 2015: use baluster per tread on stair (with no top rail?)
    By jledgewood in forum Revit Architecture - General
    Last Post: 2015-08-28, 07:05 PM
  2. stair tread.
    By Bluefairy in forum Revit - Student Support
    Last Post: 2010-08-29, 08:56 PM
  3. What controls the Baluster Per Tread spacing?
    Last Post: 2010-03-02, 05:30 PM
  4. Baluster to tread
    By trent59822 in forum Revit Architecture - General
    Last Post: 2005-10-10, 09:33 PM
  5. Baluster per tread?
    Last Post: 2005-07-12, 08:47 PM
