Results 1 to 6 of 6
Thread: Balloon Notification for Unresolved Reference Files
    ACAD Wish List Administration
    2005-06
    1,920
    Default Balloon Notification for Unresolved Reference Files
    Summary: An optional balloon notification for unresolved XREF's
    Description: If a drawing is opened which has an unresolved xref, I would like to see a balloon notification pop-up.
    How Used: Sometimes a missing xref isn't immediately apparent. This would give users a way to catch a potential problem before it is a problem.
    Feature Affinity: XREF
    Submitted By: Chris Lindner on November 19, 2007
    Earth
    9,805
    Default Re: Balloon Notification for Unresolved Reference Files
    Missing xrefs are currently noted on the command line when you open a drawing.
    R.K. McSwain | CAD Panacea |
    2015-12
    2,095
    Unfortuneately, when you have 20 drawings referenced and only five lines of text in the command window that goes by pretty fast. Even when trying to review the XREF loads in the expanded text window its easy to miss those that are unreferenced or missing.
    As long as this pop-up is controlled through a registry-contained system variable and *not* a drawing based one, I think its a good idea.
    Earth
    9,805
    So what are you picturing, a separate balloon for each unresolved xref, or a large single balloon to hold all of them, or a single small balloon with a vertical scroll?
    I'm just trying to picture how this might work...
    0,0,0 The Origin
    8,570
    I'd have thought that the scroll idea would be the most sensible and the easiest to program.
    Second thoughts = But then, I guess, you'd be no better off than by hitting F2.
    2011-08
    4,581
    Exclamation Re: Balloon Notification for Unresolved Reference Files
    The wish has already been granted. This thread is closed to further posts.
  1. Balloon Notification set to monitor 1
    By pangell in forum AutoCAD General
    Last Post: 2008-03-10, 12:09 PM
  2. Balloon Notification
    By dxarhoulakos in forum AutoCAD Customization
    Last Post: 2008-01-18, 03:43 PM
  3. Turn OFF Plot balloon notification
    By RenataP in forum AutoCAD Tips & Tricks
    Last Post: 2006-09-12, 01:05 AM
  4. Xref balloon notification
    By MikeM4OSU in forum AutoCAD General
    Last Post: 2006-02-17, 11:27 PM
  5. Printing Notification Balloon.. Gone!
    By andy.manninen in forum AutoCAD Tips & Tricks
    Last Post: 2005-12-19, 12:15 PM
