Thread: Glass in Railing
    2005-01
    4
    Default Glass in Railing
    Hi, I'm having trouble creating glass in between my top, bottom rails and inbetween the newel posts. I've been playing around with balusters but can seem to eliminate the spacing so I have 1 baluster with a narrow thickness and automatically going in between posts...
    2002-09
    Madison, WI
    5,688
    Default Re: Glass in Railing
    The stair tool (IMHO) lacks this type of funcationality. if you have a complex stair with complex (ie different) types of object (glass & steel) you may just want to bit the bullet and use masses. If you try to use the stair tool I have a feling you'll play with it forever and still not get the resutls you want.
    For guard rails, I'd think curtain wall.
    Just my thought.
  1. Glass railing Question - Corners
    By sbrown in forum Revit Architecture - General
    Last Post: 2020-07-06, 10:15 PM
  2. Glass Panel Railing
    By dboggs in forum ACA/AMEP Styles Library
    Last Post: 2017-12-06, 09:19 PM
  3. 2012: Glass Balustrade panel railing
    By damon.sidel in forum Revit Architecture - Families
    Last Post: 2012-08-08, 11:26 PM
  4. GLASS RAILING
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-07-05, 10:25 PM
