Thread: Custom arrow head
    2001-07
    486
    Default Custom arrow head
    Is it possible to have and arrow head as the one shown in this image?
    if so cuold you tell me how?
    thanks
    2002-02
    St. Louis, MO
    4,695
    Default Re: Custom arrow head
    Nope. Revit can't do those nice square edges...
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    Your arrow heads are exactly like my old hand drawn chisel 9 mm pentel ones, only more uniform. (And, most other hand drafters from "the day".)
    I tried to duplicate it years ago. (See attached image) Now, I still use this one and another one which is a filled in arrow. Aaron is correct about the square edges however. In addition, you can't create an arrow which is greater than 90 degrees, which your heads are. If you zoom into mine, you will see the edges are rounded, in true Revit fashion. You can minimize this by changing the head's line weight; however, you loose the boldness and readability in my opinion. I like it around 6 or 7, which is what I used for this example.
    Good luck
    Steve
    Steven C. Shell, Architect
    Tucson, Arizona
    www.scshell.com
  1. 2013: Dimension - Arrow head
    By stephanschneller in forum ACA General
    Last Post: 2013-03-19, 04:56 PM
  2. Arrow Head on lines
    By mjl in forum Revit Architecture - General
    Last Post: 2010-06-04, 01:47 PM
  3. When using custom arrow head a gap appears
    By jordan.wolfe in forum AutoCAD Annotation
    Last Post: 2010-01-11, 11:19 PM
  4. Key Nots leader needs arrow head
    By Kenny Gee in forum Revit Architecture - General
    Last Post: 2009-07-15, 11:49 PM
  5. Set arrow head type....?
    By aaronrumple in forum Revit Architecture - General
    Last Post: 2005-05-24, 02:22 PM
