Thread: Local Files: program to delete local file and create a new local file
    2007-01
    16
    Default Local Files: program to delete local file and create a new local file
    So the Revit masters of the world seem to recommend that you create a new local file from the central every day or two. It can be problematic to have people in the morning all opening the central file and performing a save as command (especially if someone heads to the kitchen for a cup of coffee and forgets to save the local file). I heard somewhere at Autodesk University that someone had created a little program to place on you desktop. The program will delete old local files and create a new one from the central file in its place (without ever opening the central file I believe). I think it is supposed to be somewhere on AUGI but I can't find it anywhere. Can anyone point me in the right direction?
    2005-07
    3,250
    Default Re: Local Files: program to delete local file and create a new local file
    Here you go:
    http://forums.augi.com/showthread.php?t=65897
    Happy New Year!
    2003-01
    Richmond, VA
    33
    Active Member Mike hacker's Avatar
    London
    64
    Quote Originally Posted by pkirill View Post
    I've just recently started using this one and I must say it's pretty good.
    Regards
    Mike
    2003-01
    Richmond, VA
    33
    Quote Originally Posted by Mike hacker View Post
    Very cool - glad you like it!
  1. 2012: Can't create a new local file
    By estanton in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2014-01-15, 09:15 PM
  2. Cannot create a local file
    By brenehan in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-11-01, 04:56 PM
  3. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  4. Create a local file grayed out?
    By tys90 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-06-15, 04:08 PM
  5. Can't Create Local File
    By guy.messick825831 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-11-09, 10:52 PM
