When I fired up Autocad today, I noticed that all my toolbars, pulldown menus etc were gone. I found out that the ACAD.cui file was missing from the documents and settings path. Actually the file size was set to 0. I have Registry Mechanic on my system and I did a clean up a few days ago, so I kind of suspect it may be the culprit.
This has happened twice now. I did a repair, with no luck. Has anyone seen this problem? BTW, I have Autocad Architectural so I jump between both applications, but I don't think that is causing the problem
Could use some help here.
