Thread: Converting Older Drawings to 2007/08
    Member cadmancando's Avatar
    2015-11
    Arlington, WA
    24
    Default Converting Older Drawings to 2007/08
    When opening the attached file in AutoCAD 2007/08, running "AUDIT" and "REGEN", the dimensions want to take on the existing style definition.
    If you list the dimension before running the AUDIT you will notice that the "Dimesion style: is "" (aka nil).
    Any idea's on how to stop this from happening and still be able to Audit the drawing?
    0,0,0 The Origin
    8,570
    Default Re: Converting Older Drawings to 2007/08
    I just created a new dimstyle, placed a new dimension using the new style and used "match properties" between the new dim and the "" style ones.
    Not elegant, but it worked.
    2015-11
    Arlington, WA
    24
    Forgot to say.......I have 1,000+ dwgs to do
    0,0,0 The Origin
    8,570
    That would make a difference.
    I'd try using a script to define the new dimension and make AUDIT the last entry.
  1. moving older drawings forward
    By cadtag in forum AutoCAD Civil 3D - General
    Last Post: 2010-01-16, 12:06 AM
  2. Converting multiple DWG files to older version
    By drdesignz in forum AutoCAD General
    Last Post: 2009-03-04, 09:32 AM
  3. Converting older lisp files
    By pstern44080 in forum AutoLISP
    Last Post: 2007-12-10, 02:18 PM
  4. Save multiple drawings to older versions?
    By mickb in forum AutoCAD General
    Last Post: 2007-06-20, 09:57 PM
  5. Replies: 7
    Last Post: 2006-10-25, 12:13 PM
