Thread: Metric Scale & Plot
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Metric Scale & Plot
    I have a Topo drawing that I xref'ed into my plan and did some layout work.
    My unit were set to Feet & Inch. I need to plot out the drawing @ 1:1000
    How do I set that up.???
    2002-09
    Madison, WI
    5,687
    Default Re: Metric Scale & Plot
    Do you want 1" to equal 1000' or 1' equal 1000'. I think most civils do 1"=1'-0" to begin with as they use decimal and just make it decimal feet. The main way I've seen it done is to scale the drawing down by a factor of 12 (this converts the inches to feet) make is a decimal drawing. Or do you need to make it 1 mm = 1M. If you need to do that, to convert to metric I believe you would scale the drawing by the said conversion factor.
    1' = 304.8mm. 1"=25.4mm.
    Let me know if I just made you more confused.
  1. Metric Drawing Scale
    By Joy_1611 in forum AutoCAD General
    Last Post: 2011-10-18, 08:50 PM
  2. How to set scale in Metric system
    By floorline.187438 in forum AutoCAD LT - General
    Last Post: 2011-04-22, 12:10 PM
  3. Plot a metric file in 1/2" scale
    By WDS in forum AutoCAD Plotting
    Last Post: 2009-08-24, 03:16 PM
  4. Metric scale block
    By brandenz in forum AutoCAD General
    Last Post: 2008-12-17, 09:51 PM
  5. How Does One Scale in and Convert to Metric?
    By quinn in forum AutoCAD General
    Last Post: 2005-01-20, 10:40 PM
