Per Wes's recommendations in an earlier post, I have done some tweaking of ForceWare settings, but I have some questions that hopefully someone has answers to.
nVidia ForceWare 162.65 and cards ranging from Quadro FX 500/600 up to a bunch of FX 3500s
Anisotropic Filtering: OFF
Vertical Sync: OFF
Trilinear Optimization: OFF. Where is this setting in 162.65? I can find it in the help file, but not the actual setting.
Also, anyone played with these settings?
Enable Overlay Plane: OFF by default. Is this related to Revit's Overlay plane setting? Is OFF a bad thing? Is ON a good thing?
Multiple-display/Mixed-GPU acceleration: Compatability Performance Mode by default. Anyone played with Single Display Performance Mode for single monitor users?
ATI Cataliyst 8.44 and cards ranging from V3100s up to some V7200s.
Vertical Refresh: OFF
Anyone have any solid information that these settings are indeed the same as the nVidia ones? Do you see good results with the same settings in Catalyst?
And on both options, are people using Revit specific settings globally, or setting things up with independent Revit settings? Any arguments one way or the other? Note, I am asking relative to a non 3DS MAX environement. I thing I would want independent settings if I was running both.
Gordon
