Results 1 to 10 of 13
Thread: Files already open freeze and lock read only intermittently
    2008-01
    3
    Default Files already open freeze and lock read only intermittently
    For the past month we have been experiencing intermittent locking of our drawings after they have been opened and worked on. The drawing wil freeze and the drawing name will all of the sudden have read only after it and the user cannot save his work.
    We have tried to link it to things like our backup system coming on but have not found a common element to cause this. Has anyone else had this problem?
    2008-01
    3
    Default Re: Files already open freeze and lock read only intermittently
    We are using Autocad 2006
    2005-09
    Georgia
    82
    We've had it happen a couple of times too. I noticed ours didn't start until we began using the vault.
    2008-01
    3
    We are not using Vault.... Any other suggestions?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Please note I have moved this to the AutoCAD General forum from the non-technical "New User's forum".
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2015-12
    4,730
    Are you using any file accelerators for your WAN like Riverbed or Avail (or both)? I've one other case of this where the dwl file is removed during autosave and another user tries to open the file at the same time and gets it open. It might be a combo of these but the customer never got back to me if they tracked down the source of the culprit.
    2015-12
    4,730
    Please do not use "Multiple-Forum Posting" per forum guidelines.
    2007-09
    16
    We have this problem...It happens when a user has a file open and then another user opens that file...the locked is missed and the user who had originally opened the file goes into read only.
    Any ideas on how to fix it....we are using riverbed...but this does happen with users sitting next to each other in the same building.
    2008-03
    We have had this intermittently happen. Today as a matter of fact.
    We do have Riverbed but this occurred on the same network in the same building on the datacenter side. Not through the Steelhead. Although I don't know if the Steelhead is involved somehow.
    Could digital signatures, which we turned off be somehow involved?
    We are using MEP 2008 and Arch 2008, Civil3D.
    Any resolve to this or anyone know if this is something we have to put up with?
    The users currently follow a procedure, if they know someone opened their file, they contact the other user, have them close the file so the first user can save their changes.
    Thanks
    H. Wu
    Information Systems Manager
    C2AE
    725 Prudden Street
    Lansing, MI 48906
    P: (517) 371.1200
    2015-12
    Chesterfield, MI
    405
    I have seen this happen when an AutoCAD users computer momentarily loses network connectivity - I've seen this happen during a scheduled/automatic virus scan update. In some instances when it reconnects to the network it appears to recognize the lock file as being held by someone else.
  1. ISOLATEOBJECTS to include the option to Lock, Freeze & VP Freeze
    Last Post: 2014-11-08, 06:22 PM
  2. Open Read-Only: The ability to open a worksharing enabled file in a read only mode.
    Last Post: 2012-09-05, 07:02 PM
  3. Replies: 3
    Last Post: 2012-06-28, 03:51 PM
  4. Freeze on open
    By jnj1502 in forum ACA General
    Last Post: 2007-02-05, 03:51 PM
  5. Replies: 2
    Last Post: 2005-12-04, 03:31 PM
