Results 1 to 7 of 7
Thread: Profile layout tools unusable?
    2007-06
    Default Profile layout tools unusable?
    Has anyone ever had their profile layout tab or alignment layout tab be gray (not usable)? I need to remove a PI and I can't. I can modify it by clicking and dragging it, but I can't use the tools on the layout tool bar. I just had it happen with a profile too. Help!
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Profile layout tools unusable?
    Is this a Civil-3D question?
    If so, there has been an odd bug that periodically causes that toolbar to become unusable. Shutting down and restarting C3D fixes it. I believe it is still a mystery as to why or when this happens.
    The usage of that toolbar is also a little strange. It actually gets "linked" to a profile or alignment when you right-click a profile or alignment and select "Edit geometry". So sometimes you might have it linked to one profile while you are trying to edit another profile. To keep from getting confused, it helps to close that toolbar as soon as you finish editing an alignment or profile, so you always open it fresh whenever you need it.
    2009-07
    6
    Is there still no work around / solution other than restarting Civil 3D? I run into this problem pretty often
    Earth
    9,819
    It's still an issue in C3D 2015.
    R.K. McSwain | CAD Panacea |
    2016-08
    Still an issue with C3D 2018.
    2015-10
    73
    Still an issue in 2021.
    2009-11
    5,726
    Quote Originally Posted by rickquin651723 View Post
    And for 2022, FWIW.
    Quote Originally Posted by sinc View Post
    The only way I've been able to continue - without restarting Civil 3D (and this doesn't always work) - is after the toolbar becomes 'linked to a Profile and no longer works, is to open the toolbar for another Profile (sometimes multiple) before it will 'work' again, then go back to the Profile I was attempting to edit.
    Computer Specs:
  1. PROFILE LAYOUT TOOLS BLOQUEADO
    By luisito_210675 in forum AutoCAD Civil 3D - General
    Last Post: 2014-10-07, 07:01 PM
  2. 2011: AGREGAR ESPIRALES CON ALIGNMENT LAYOUT TOOLS
    By wellch85 in forum AutoCAD Civil 3D - General
    Last Post: 2011-09-08, 04:40 AM
  3. Convert Surface Profile to Layout Profile
    By brian.hailey933139 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2010-07-17, 04:25 AM
  4. Metal studs/Woods stud layout Tools
    By pugander in forum Revit Structure - Wish List
    Last Post: 2009-09-18, 12:03 AM
  5. Layout Profile Linked to Surface Profile
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-06-02, 03:11 PM
