Thread: mvpart System
    2007-10
    Tucson, Arizona
    613
    Default mvpart System
    When I create a mvpart and then add it to the tool palette, I would like to have the default System for the connections be preset. I can right-click on the mvpart and select "mvpart Properties" to set the System to be Supply (for example), and then drag/drop the mvpart to the tool palette, but it doesn't remember the System setting. Is there a way to have the mvpart come in with this default System set?
    -Buzz
    2007-10
    Tucson, Arizona
    613
    Default Re: mvpart System
    Ugh... from Autodesk:
    Unfortunately this feature is not available yet. I'm not sure if and when it will be added. For now, you can insert the mvpart into your drawing, set the system, and then copy this as needed.
    bummer...
    -Buzz
  1. MVPart scheduling
    By jasonp in forum AMEP General
    Last Post: 2011-03-07, 12:00 AM
  2. mvpart System Type
    By buzz in forum AMEP General
    Last Post: 2010-04-29, 05:10 PM
  3. MVPart visibility
    By Gaz62 in forum AMEP General
    Last Post: 2009-11-05, 08:17 PM
  4. EDIT MVPART
    By kmf2797 in forum AMEP General
    Last Post: 2008-06-03, 08:58 PM
  5. mvpart add Delay
    Last Post: 2008-02-04, 09:51 PM
