This thing is baffling to me. I have a project file with 4 linked DWG files. When I first opened the project, it said the files could not be found at Z:\blah blah blah (network path location) and they would be loaded as they last appeared or something like that.
So I go to Manage Links, re-load every file (which goes fine, no errors) and change all the paths to absolute. Just to double-check, every file is in fact located at the location listed in Manage Links.
So then I save and close, then open the file again, and I STILL get the same error about the linked files could not be found! arggghhhh I even just opened each and every DWG file in AutoCAD, they all open fine, but Revit still says it can't locate the files! What is going on here??
