Is there any way to set the default corner seam behavior in the sheet metal template? Right now a simple corner seam always puts a gap approximately the metal thickness, I need to make that smaller as the default behavior.
Thanks
Thanks
As far as I know this isn't a value that you can set in any default table. It's an un-named parameter in the table and it changes locations in the table depending on construction (making it kind of a pain).
Dang! I thought you could and it looks like i'm wrong.
One thought as a workaround though.
Create a user parameter in the Sheet Metal template, then when you create your corner seam, use the 'List Parameters' option to put the value in the dialog.
At the very least, you don't have to type the number over and over again, plus it does grant you the abilty to change the default in one place (the parameter table).
Jonathan Landeros
KETIV Technologies
Orange County, California.
I've got a blog: www.inventor-tales.blogspot.com
“We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
