Thread: outlet display???
    2003-05
    Dillon, Co
    5
    Default outlet display???
    how do I get the outlet above the storefront to display on the plan?????
    Electrical fixtures are turned on in visibility
    2003-10
    Santa Barbara
    397
    Default Re: outlet display???
    in visibility settings make sure "electrical fixtures" are turned on.
    2003-04
    Chino, CA
    4,756
    Try using a plan region to bring the outlet into the plan. I think its above the cut plane.
    Another trick you can do is to open the outlet family, and draw an invisible line vertically down from the outlet long enough that it will be intersected by the cut plane. Then reload in your project and it should display.
  1. Education Outlet?
    By Blitsch in forum Training
    Last Post: 2018-12-22, 06:48 PM
  2. Sanitary Outlet
    By radams.142604 in forum Revit MEP - General
    Last Post: 2008-05-02, 11:55 AM
  3. Looking for outlet
    By harkeychad in forum Revit Architecture - Families
    Last Post: 2007-07-16, 06:51 PM
  4. Looking for outlet
    By harkeychad in forum Revit Architecture - General
    Last Post: 2007-07-16, 02:39 PM
  5. Outlet Scale
    By dsw98 in forum Revit Architecture - General
    Last Post: 2005-11-10, 05:49 PM
