sharla
I need to create a door window assembly that will span across two walls in plan. One wall is curved and merges w/ a straight wall at a point but the assembly is located in both walls. How do you get this to work?
I'm attaching a drawing containing the walls. What is shown right now are individual windows and a seperate door because we are just beginning to use door/window assemblies (thanks to AU 2007!) You can see that a bit of wall shows between the door and windows because that is right where the two walls merge.
How do I get this to work correctly w/ an assembly? Am I drawing my walls incorrectly for this type of condition?
