Kinda like this?
;;; vpf.lsp Viewport Layer Freeze
;;; ARGUMENTS
;;; none
;;; USAGE
;;; vpf
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2005-2007 Charles Alan Butler
;;; ab2draft@TampaBay.rr.com
;;; VERSION
;;; 3.2 May 17, 2006
;;; This routine will Freeze the layer of a selected entity in ALL tabs
;;; and ALL viewports except the active viewport , selected layers are
;;; frozen while selecting & restored in the active viewport
;;; If you run the routine in model space it will freeze in ALL viewports
;;; YOU MAY USE THIS CODE ONLY FOR *NON-COMMERCIAL*
;;; PURPOSES AND ONLY IF YOU RETAIN
;;; THIS HEADER COMPLETE AND UNALTERED
;;; you must contact me if you want to use it commercially
;;====== Main Lisp Routine =======
(defun c:vpf (/ oldcmd vpflag sel-vport entvport pik str laylist ms layout c-tab *error*)
;; error function
(defun *error* (msg)
(if (not (member msg
'("console break" "Function cancelled" "quit / exit abort"))
(princ (strcat "\nError: " msg))
(if (/= laylist "")
(if ms
(command ".-layer" "thaw" laylist "")
(command ".vplayer" "t" laylist "All" "" ; reset selectd layers
".pspace")
(setvar "CMDECHO" oldcmd)
(princ)
) ;end error function
(setq oldcmd (getvar "CMDECHO")
c-tab (getvar "ctab"))
(setvar "CMDECHO" 0)
(if (= (getvar "TileMode") 1) ; in model space
(progn
(prompt "\n**** Layers chosen will be frozen in all viewports.")
(setq ms t)
(progn ;else in a layout
(setq vpflag (getvar "cvport")) ; get viewport #
(while (= vpflag 1) ; No active viewport, Loop until one is picked
(setq sel-vport (car (entsel "\nSelect view port: ")))
(if (= sel-vport nil)
(alert "You must select a viewport\n --=< Try again! >=--")
(progn
(setq entvport (entget sel-vport))
(if (= (cdr (assoc 0 entvport)) "VIEWPORT")
(progn
(setq vpflag (cdr (assoc 69 entvport))
(command ".mspace")
(setvar "cvport" vpflag)
) ; endif viewport
) ; endif cond sel-vport
) ;endwhile (= vpFlag 1)
) ; endif
;; Get Entity and Freeze Layer
(command "undo" "begin")
(while (setq pik (entsel "\nSelect an item whose layer to freeze: "))
(setq str (cdr (assoc 8 (entget (car pik)))))
(if laylist
(setq laylist (strcat laylist "," STR))
(setq laylist str)
;; Freeze selected layers for visual feedback
(if ms
(if (= str (getvar "clayer"))
(alert "Layer current, will be frozen in viewports.")
(command ".-layer" "freeze" str "")
(command ".vplayer" "f" str "All" "")
(cond
((/= laylist "") ; Freeze layers in ALL viewports and ALL TABs
(setvar "TileMode" 0) ; Force Paper Space
(foreach layout (vl-remove c-tab (layoutlist))
(setvar "ctab" layout)
(command ".vplayer" "f" laylist "All" "")
(if ms
(progn
(setvar "TileMode" 1) ; Back to Model Space
(progn
(setvar "ctab" c-tab)
(command ".vplayer" "t" laylist "Current" "") ; restore working VP
((/= laylist "")
) ; end cond stmt
(command "undo" "end")
(princ)
) ; end defun
(prompt "\nType VPF to run")
(prin1)
