Results 1 to 10 of 20
Thread: Model lines <-> Detail lines
    2005-12
    86
    5
    Default Model lines <-> Detail lines
    It isn't possible to change model lines directly into detail lines or vice versa.
    Until now, we have used this technique:
    1. Make a view that just contains the relevant lines.
    2. Save the view as a DWG.
    3. Import the DWG. If you need drafting lines, check 'Current View Only' (Uncheck for model lines)
    4. Explode the DWG.
    But now, we've found a new way:
    1. Cut the lines to the clipboard.
    2. If you need model lines, start a new sketch-based model element (e.g. a Floor); If you need drafting lines, start a new Filled Region.
    3. Paste the clipboard contents into the sketch of the Floor or Filled Region.
    4. Select the lines again, and copy to the clipboard.
    5. Quit the Floor or Filled Region
    6. Paste the lines back into the model.
    It seems as though, when you copy lines out of a model-sketch, they become model lines, and when you copy them out of a filled-region-sketch, they become drafting lines.
    I could stop if I wanted to dfriesen's Avatar
    2003-05
    Vancouver, B.C.
    470
    Default Re: Model lines <-> Detail lines
    OOooo, very clever! Thanks for that tip!
    Daniel Friesen
    I could? I don't think so...
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    839
    I wanted to have known that a year ago, and at least once a month from then. TYVM!!
    LinkedIn
    "Too many variables!" - Mordin
    2007-02
    9
    Now that's what I've been looking for in a while thanx
    2006-10
    Lincoln, NE
    98
    NICE!!.......................................
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Never noticed that. Good fined!
    2007-01
    7
    Wow - what a great tip! Thanks!!
    2006-03
    London, UK
    810
    Good find!
    Of course, there should be a button to do it autmoatically
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    404
    Thumbs up Re: Model lines <-> Detail lines
    I LIKE it!
    2009-03
    4
    Cool Re: Model lines <-> Detail lines
    Wow,so great!
    Thanx.
  1. 2014: Cannot Convert Model Lines to Detail Lines
    By antman in forum Revit Architecture - General
    Last Post: 2013-10-08, 05:10 PM
  2. Model Lines vs. Detail Lines Interesting
    By dduarte in forum Revit Architecture - General
    Last Post: 2009-08-06, 04:03 PM
  3. Ability to convert detail lines to model lines and vice versa
    Last Post: 2008-03-10, 10:11 AM
  4. Turn model lines to detail lines.
    By dpasa in forum Revit Architecture - General
    Last Post: 2007-03-04, 01:26 PM
  5. Changing Model lines to detail or symbolic lines
    By Jason in forum Revit Architecture - General
    Last Post: 2005-05-21, 10:36 PM
