Thread: 1050c will not plot paperspace
    2007-08
    Central California
    38
    Default 1050c will not plot paperspace
    Hi - I am using Acad 2008 with a HP 1050c plotter. I have a dwg with an image attached and until recently have been able to plot paperspace. Since Friday, I am no longer able to plot the paperspace items. Any thoughts? Thanks for the help!!
    2015-11
    Jo'burg SA
    4,512
    Default Re: 1050c will not plot paperspace
    A few questions:
    Was it since you added the image that it doesn't want to plot?
    Does the model space plot without hitches?
    Is your plot paperspace last checked in the plot dialog? If so then there's an entity with an error in paperspace. Run audit and repair errors.
    Are you using the Windows driver or an HDI driver for AutoCAD? I've found that the HDI is usually mode stable than the windows drv - although that's for an OCÉ laser plotter and Canon Wideformat Inkjet Colour, I don't use HP.
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    Quote Originally Posted by KJBIKE7 View Post
    I have had it where the layout went corrupt on me. Create a new layout and copy and paste all the items over to the new layout. See if that fixes your problem.
    Steve Balliet
    Craig Co., VA
    Civil 3D, Mechanical 2012
  1. How Do I Plot PaperSpace View w/ NO Offset?
    By chillme1 in forum AutoCAD Plotting
    Last Post: 2009-01-14, 12:19 PM
  2. Replies: 2
    Last Post: 2007-07-29, 12:15 PM
  3. Plot from Paperspace, Plot not centered on output
    By abroseDDG in forum AutoCAD Plotting
    Last Post: 2007-03-22, 06:29 PM
  4. Plotting Shaded Views from Paperspace - HP 1050C - Views shift around
    By mckishen in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-04-07, 02:47 PM
  5. Image attached to Paperspace does not Plot
    By captcoro in forum AutoCAD Plotting
    Last Post: 2006-01-24, 12:04 AM
