I'm looking for a 11x17 scanner that will scan directly to a PDF.
"digital sender"
anybody use anything like this that can suggest some models?
looking to spend under 2,000
thanks
"digital sender"
thanks
G'day
I cant offer anything specific on scanners but if you have Acrobat 6 it'll allow you to create a PDF from any scanner. I'd highly recommend Canon scanners, in Oz there inexpensive and easy to use.
HTH
Thanks, I did know that though... I guess I needed to be more specific.
I need a 11x17 form feed scanner....
I need to be able to place a stack of 20+/- sheets and let it create 1 pdf.
I don't think there are any scanners that save out directly to PDF. You will need to buy software to do that. The one I use is OmniPage Pro 14.0. Here is a review from CNET.
Usually, when I need to create a mutli-page .pdf file, regardless or page size, I simply use Acrobate reader and add pages. Using Adobe Acrobat 4.0, click on Document>Insert Page.
Hi GlennOriginally Posted by gpope
Sorry, give the HP 9100C Digital Scanner a look over (we have them here within the office, scan directly to PDF).
Mike
Hi
Please note I've *moved* this thread from the Coffee Without CAD Forum to this one as I feel this particular Forum is a more appropriate place for such a topic (I believe the Coffee Without CAD Forum will be spring cleaned once in a while).
Thanks, Mike
Forum Moderator
thanks for the move mike, i realized i should have posted in hardware after the post.
That is very similar to what I'm looking for but I need it to be 11x17
Hey, stop proving me wrong. I don't like it when people prove me wrong. I get very angry. Maybe that's why I'm always angryOriginally Posted by Mike.Perry
Good find.
Hi
Sorry about that Hulk, I mean Glenn (thought you were looking a bit green).
11 x 17 ok! in real world measurement units A3 420 x 297 (approx), the following are probably out of the price range you quoted originally (due to them being multi functional systems) -
Minolta Di351 or Di650 or CF1501 or CF3102e
All the above will scan to PDF A3 size.
We have all of the above systems here in this office, generally speaking they're all pretty good.
Have a good one, Mike
Last edited by Mike.Perry; 2004-08-26 at 11:14 AM. Reason: Poor attempt at humour added
