What problem i face in circular x referencing that all the new layers gets turned on when is introduced. i want by default it should be frozen so that i can turn based on requirement.
How do you handle Circular x referencing
Hi
System variable VisRetain may help (sorry I don't fully understand your query).
Might also want to have a read of the following, comes from an old ACAD Guild thread -
-----Original Message-----
From: Popovici Alexandru [mailto:axa2001ro@yahoo.com]
Sent: 17 July 2003 09:35
To: guild-acad@augi.com
Subject: [ACAD] nested XREF
Hello!
I use very much xref files. Is there a limit for the level of nested xref files?
For example xref1 is xrefed in xref2 which is xrefed in xref3 .... which is xrefed in xrefN.
How bigger can be this N?
Thank you!
Sent: 17 July 2003 10:59
To: 'axa2001ro@yahoo.com'; guild-acad@augi.com
Subject: RE: [ACAD] nested XREF
Hi
I don't believe there is a limit (this is where someone proves me very wrong), but "you" want to be careful of *Circular* references as thay can cause problems and confusion... over using *Nested* Xrefs can also making working on drawings very difficult for others who don't fully appreciate/understand "your" logic behind it.
*Nested* Xrefs can be useful don't get me wrong but I personally think "you" have to be very careful when deciding to use them, again this is mainly for the benefit of others that may need to work on "your" drawings.
Personally I always go with *OverLay* where ever possible, helps keep things nice and simple for others (but mainly for myself).
Have a good one, Mike
Sent: 03 August 2003 13:45
To: 'axa2001ro@yahoo.com'; 'guild-acad@augi.com'
Hi
Am going to prove myself wrong
Check out the following Technical Document on the AutoDesk web site under the Knowledge Base section -
ID: TS43358 - Maximum number of files that can be open simultaneously
Sent: 04 August 2003 14:48
Hi
Even more info on *Circular* references -
ID: TS22417 - Circular references explained
