Results 1 to 8 of 8
Thread: Trim not trimming, extend not extending
    AUGI President Kimberly Fuhrman's Avatar
    2015-10
    York, PA
    63
    Default Trim not trimming, extend not extending
    We are using ACAD 2008. One of our users is using the basic TRIM and EXTEND commands, however the entities are not trimming or extending. He clicks on the entity to trim, and nothing happens. The layer is not locked. It is not a block. It is not an XREF. It is just a line crossing another line. Any suggestions? It is not drawing specific.
    It requires a very unusual mind to undertake the analysis of the obvious.
    --Alfred North Whitehead
    Kimberly Fuhrman, LEED AP BD+C, Assoc. AIA
    2015-10
    York, PA
    63
    Default Re: Trim not trimming, extend not extending
    PS...all the 'Z' values are zero...
    150700
    3,434
    Quote Originally Posted by dekmf43 View Post
    Have you checked the trim/extend options (like projection and edge)?
    2015-10
    York, PA
    63
    Yes. All are set correctly.
    150700
    3,434
    Would it be possible to post the drawing?
    0,0,0 The Origin
    8,570
    TRIMMODE = 1 ?
    John B
    2007-05
    Oklahoma City
    17
    There shouldn't be any issues with trimming lines to other lines. You might select all objects in the drawing, then use the Properties palette to globally change the elevations of each object type to "0". See if that helps. Sometimes, it can be difficult to trim lines back to splined polylines or arcs.
    2004-07
    Detroit Michigan
    2,508
    Lines on top of lines? Try the overkill command.
  1. Trim is not Trimming whole line...
    By robdg in forum CAD Management - General
    Last Post: 2008-06-03, 06:36 PM
  2. trim/extend
    By kwanjuju in forum AMEP General
    Last Post: 2008-03-17, 06:57 PM
  3. Trim not trimming back to selected trim boundary
    By Wwhite72082 in forum AutoCAD General
    Last Post: 2007-03-23, 01:47 PM
  4. Trim and Extend, trimming back, extending, too far
    By Mamma Jamma in forum AutoCAD General
    Last Post: 2006-10-31, 09:33 PM
  5. Trimming/Extending to an xref
    By dmcmillan.50355 in forum AutoCAD General
    Last Post: 2006-08-26, 03:16 PM
