nogienugz
Hi,
I tried to customized my own title block for a batch of our drawings, tried to insert fields (title, scale, revision number, etc.) using ATTDEF, and made the title block in to an autocad dwg. block saved it as a .DWT file. Each of the drawings would use this template as their layout.
The problem is, when I tried to update the fields using the "properties" of the SSM, the value of the fields doesn't change, unless I erase the original block and re-insert the new one. So every time a change the value of the fields I have to re insert the "title block" block again to reflect the new data.
I already mapped my default template file location to the folder of my newly created drawing template but I still hadn't solved this one. Does anyone knows how to fix this?
