Thread: Properties palette displays only the general properties ??
    2002-12
    10
    Default Properties palette displays only the general properties ??
    I am using Acad2004, I select a circle and use properties command (ctrl + 1) to display the properties palette, but it's only display the general properties, I remember that last time can show misc properties for us to check & modify the radius/diameter. Is there any setting to set for the properties command?? please help, Thank You.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Properties palette displays only the general properties ??
    2002-12
    10
    Thanks Gpope, I will go through that page.
    Thanks
    13,657
    Hi
    Please note I've *moved* this thread from the AutoCAD Customization Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
  1. Replies: 1
    Last Post: 2013-12-04, 06:14 PM
  2. Replies: 5
    Last Post: 2009-01-08, 02:35 PM
  3. View Solid Mass Properties in Properties Palette
    Last Post: 2007-09-28, 02:29 PM
  4. Object properties palette not showing selected Objects properties
    By timothyjturner in forum AutoCAD General
    Last Post: 2007-08-10, 05:21 PM
