Results 1 to 10 of 11
Thread: Byblock property
    2015-10
    Trencin, Slovakia
    80
    Default Byblock property
    I have a layer which lineweight is set to 0.5mm.
    I have put two blocks to it. One is made of elements on layer 0 and with lineweight property BYLAYER, second is made of elements on layer 0 and with linweight property BYBLOCK. Both blocks have lineweight property BYLAYER.
    Both blocks are displayed with wide lines on the screen, but only that with BYLAYER elements is ploted correctly. Is it normal? Logicaly i would expect the plotting according i see it on the screen. Wat could be the problem?
    2005-06
    in the upper right corner
    3,518
    Default Re: Byblock property
    Quote Originally Posted by peter.sedlacek View Post
    I think you need to change the lineweight that's set to ByBlock to ByLayer to fix this problem.
    2015-10
    Trencin, Slovakia
    80
    Byblock property is useful for my workflow. I expected, that if blocks property is bylayer, entities inside block set to Byblock take the property Bylayer, but it is obviously not true.
    Isn't it illogical?
    2005-06
    3,518
    Ok, now that I had a chance to re-read your original post again, let me ask you some questions:
    How are you plotting your drawing? With color tables (CTB), style tables (STB) or line weights assigned per layer (with maybe monochrome.ctb)?
    If you're using color (CTB), that may be overriding the line weight you have assigned to the layer, or the line in the block that is ByBlock when you plot.
    Maybe you could post an example with a these two blocks?
    2015-10
    Trencin, Slovakia
    80
    I use plotstyles with lineweight set to USE OBJECT LWT. here are examples:
    2005-06
    3,518
    I think I figured it out. I checked the properties of the line your "Block02" and the "Plot Style" was set to ByBlock, I set that to ByLayer and it plots correctly while maintaining the line weight being ByBlock.
    See attached plotted PDF and drawing, I created a couple more layers to test.
    2015-10
    Trencin, Slovakia
    80
    Thanks, i tried to plot your drawing with the same plotstyle and plot is different.
    2005-06
    3,518
    Gee, I don't know.
    I tested it again on my end, tried plotting it to a printer as well, it prints fine.
    I used your .stb file too.
    The line weights appear correctly on the screen and they plot fine too (per layer).
    Did you try "print preview"?
    Do the line weights appear correct on the preview?
    2015-10
    Trencin, Slovakia
    80
    Gee, I don't know.
    Yes, i tried, in plot preview it looks not correctly. either on printer or in pdf.
    Member ameave's Avatar
    2007-02
    25
    The elements inside the block that are "BYBLOCK" will take the assigend property of "The BLOCK". Select your block and assign the correct pen width manually from the "Pen Width" pull down menu.
  1. Replies: 10
    Last Post: 2013-12-17, 04:25 PM
  2. 2012: ByBlock vs ByLayer options
    By Darren Allen in forum AutoCAD General
    Last Post: 2012-11-26, 08:36 PM
  3. Replies: 1
    Last Post: 2008-05-16, 05:57 AM
  4. Styles - Why is linetype set to byblock?
    By jpaulsen in forum AutoCAD Civil 3D - General
    Last Post: 2006-11-16, 08:04 PM
  5. Replies: 0
    Last Post: 2004-09-21, 08:00 PM
