Thread: Viz Help
    2007-09
    3
    Talking Viz Help
    I have to take a Architectural 2 project i made and make a scale model along with a Autodesk Viz project. I have 2 questions:
    #1. I can import my ADT Architectural 2 project in Viz but only 1 construct at a time. Is there a way to import all the constructs as 1 into Viz? I also tried importing them 1 by 1 but they over lap. If you cant import all constructs as 1 part then how do i adjust the elevations for each construct?
    #2. What are some good resource and tutorial sites for Viz?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,722
    Default Re: Viz Help
    Welcome to AUGI and congrats on your first post!
    First thing I would do in ADT is to create a view drawing containing all files that make up your building. Provided you've assigned them to the correct levels in the project you should be good to go. Open the view, save it and close it. Then link that file into VIZ.
    As for your second question, please refer to the sticky at the top of this forum.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
