I'm assuming you've created a SCR file. In which case you should find the ACADDOC.LSP file (usually in C:\Documents and Settings\<<User Name>>\Application Data\Autodesk\AutoCAD 2008\R17.1\enu\Support\ - at least in XP). If it doesn't exist create it with a text editor (such as Notepad). This file will be loaded & run for each drawing opened.
Place the SCR file in a shared directory (e.g. on your server), or create a copy in each user's PC (same folder as above). Add the following code to the ACADDOC.LSP file, assuming the SCR file is called SCALEREM.SCR and placed in a server folder S:\SCRIPTS\:
(setq oldfiledia (getvar "FILEDIA")) ;Save value of FileDia system variable
(setvar "FILEDIA" 0) ;Set FileDia to 0 to use command prompt only
(command "_SCRIPT" "S:\\SCRIPTS\\SCALEREM.SCR") ;Run the script
(setvar "FILEDIA" oldfiledia) ;Set FileDia back to previous value
(setq oldfiledia nil) ;Clear variable used for FileDia
If the SCR file is placed in the Application Data folder mentioned above (or any AutoCAD search path) you can omit the path in the (command line in the lisp above, just have the file name.
BTW, could you share this script here?
