Results 1 to 10 of 11
Thread: Puzzled roof (warpped)
    2002-09
    Madison, WI
    5,687
    Default Puzzled roof (warpped)
    So my find Designers decided that it'd be cool to creeate a warpped/slopping roof.
    Anyone have any good ideas how to add individual panel on this thing. Each bay is bascially twisted. (Except for the cols along lines A-L and A-A, every col has a different top elevaiton) See attached drawings.
    I'm open to any suggestions. I know what I'm going to get isn't going to be that smooth, but that's my point. I need to be able to show the designer that what he is asking for is not only a detailers nightmare, but isn't going to work so good with standing seam roofing.
    Thanks in advance.
    2005-06
    Brisbane-Australia & Phoenix Arizona
    80
    Default Re: Puzzled roof (warpped)
    Can't open your drawing file so I am not 100% sure of what you need but.....
    I think I know what you're after.
    In that case draw an outline of the roof as a polyline in the correct UCS.
    Draw a polyline the length of the roof surface from front to back and have
    it curve the way you want.
    Extrude the outline polyline along the curved polyline as the path for the
    extrusion.
    You can convert the extrusion into a solid and then into a roof slab.
    Leo
    2002-09
    Madison, WI
    5,687
    The only way you can do it is to create a mesh, or find a sphear that matches the bends. There's no one line you can extrude around or though. It's a non-planer object, with a thinkness.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Make it in revit and export as ACIS solids?
    Are we getting graded on this test?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-09
    Madison, WI
    5,687
    Quote Originally Posted by Steve_Bennett View Post
    Ok Smarty, How do I make it in Revit?
    Oh I should say I only have RS. Last I check you couldn't do a twisting slab there either. But I don't know anything. I'm just a muddler.
    2015-12
    4,730
    Quote Originally Posted by david_peterson View Post
    I could swear I saw them toting warped roofs as a new kick butt function revit for 2008 flavors... I haven't done it so I'm not smart on it - I've just seen it.
    2005-07
    2,356
    Okay, I've created a 3dmesh (20x10 but it could be smoother if needed), not sure what to do next though, I can't figure out how to give it a thickness or convert to a mass element.
    Not sure if it's much use to you though.
    2002-09
    Madison, WI
    5,687
    Yep, that why I think I actually just used a face, since that's how it's going to be built anyway.
    Fun little challenge though. I think I may actually have a lisp floating around here somewhere that will take a mesh and extrude it. Then again, maybe that was a region. I'll have to go look.
    2005-07
    2,356
    You could copy the mush up say 1' (or whatever roof thickness) then just fill in what would be the fascia's.
    It's not warped very much though is it?
    2002-09
    Madison, WI
    5,687
    The only reason I had to model it was so my fine designer types could look at it and figure out weather or not they were going to be able to attach the standing seam roof to the top of my deck. I know the deck will go. You just have to make sure the guy welding it on weighs about 200lbs. He'll just bend it right into place.
  1. puzzled! eWasOpenForWrite error
    By 289924688488291 in forum Dot Net API
    Last Post: Yesterday, 05:59 PM
  2. Making a tiled or slated roof trim overhang the roof line.
    By PeterJ in forum Revit Architecture - Tips & Tricks
    Last Post: 2019-12-23, 11:27 PM
  3. Roof problem : trss roof does not intersect exterior wall correctly
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-01-29, 05:37 PM
  4. Puzzled by mpedit?
    By ddempsie in forum AutoCAD General
    Last Post: 2007-11-12, 01:31 PM
