Results 1 to 6 of 6
Thread: brep - is there a setting to turn off history for the entire dwg?
    2007-03
    20
    Default brep - is there a setting to turn off history for the entire dwg?
    I know using brep, you are able to select all solids in the dwg that you would like to turn the history off of, but is there a setting to have all history turned off automatically?
    Earth
    9,805
    Default Re: brep - is there a setting to turn off history for the entire dwg?
    What is "brep"?
    R.K. McSwain | CAD Panacea |
    0,0,0 The Origin
    8,570
    Undo
    Control
    None
    turns off command history but I don't really think that is what you're looking for.
    2007-03
    20
    brep is a command used in 3D modelling. It turns off the history of objects, after you have modelfied an object. say you subract a box from a cone, the cone has a new shape but the box dosnt appear. but the history of the box will still be there. brep allows you to delete all this history, but you have to do it after the shape is made all the time. I was wondering if there was a setting that you could have where this history is automatically erased.
    0,0,0 The Origin
    8,570
    I'm pretty sure the answer is "no". Almost all modelers are history-based (which seems to be what you're talking about). The only exceptions that I know off are Co-create SolidDesigner and SpaceClaim. (PTC have bought SolidDesigner so non-history operation is likely to be added to Pro/E sometime).
    In your example, if you had filleted (blended) the edges of the box before subtracting it from the cone you wouldn't be able to alter the radius after after subtraction without the history.
    2015-12
    Owasso, Ok
    18
    Smile Re: brep - is there a setting to turn off history for the entire dwg?
    If you set your System Variable SolidHist to 0 than no history is retained with any new solids created. This is system variable is saved in the drawing.
    HTH
  1. Clear History or Turn off History
    Last Post: 2013-11-05, 07:12 AM
  2. 2013: collaborate - show history function - What's the History?
    By david_peterson in forum Revit Architecture - General
    Last Post: 2013-02-28, 10:31 PM
  3. Turn Lineweight setting OFF via Script or Macro or...
    By alanr in forum AutoCAD Customization
    Last Post: 2006-06-21, 06:30 PM
  4. Save reminder - system setting or project setting?
    Last Post: 2005-07-08, 01:47 PM
  5. Turn off "Overlay" setting to improve performance
    By narlee in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-10-27, 07:44 PM
