Results 1 to 1 of 1
Thread: Programming Application problem
    2007-04
    Default Programming Application problem
    I'm the CAD Manager of a Civil Engineering firm. We're currently using Civil 3D 2008 and Land Desktop Companion 2008 with service pack 2. An employee that used to work with us still helps out when available. He is a programmer. He has written an application which he installed on the 2002 products and upgraded to the 2006 products. He has come across a problem trying to tweak this application and get it to work with our 2008 products. Programming is not my strong point. If it's not a problem, I would like to attach the document where he describes in programming language the issues, and hopefully a programmer, or someone, can lead us in the right direction. Any help is greatly appreciated.
    Jason
  1. CP9114-1: Getting Started with AutoCAD Civil 3D Application Programming Using .NET
    Last Post: 2014-12-01, 02:12 AM
  2. Replies: 1
    Last Post: 2013-04-25, 01:09 PM
  3. Replies: 0
    Last Post: 2013-04-17, 04:22 AM
  4. TrueView problem open application
    By AMD2800 in forum DWG TrueView - General
    Last Post: 2009-10-12, 03:53 PM
  5. Vertical Alignment Editor - Problem in loading application
    By jpaulsen in forum Land Desktop - General
    Last Post: 2005-10-05, 05:53 PM
