Thread: Using LISP and/or Visual LISP to find something
    2007-02
    Calgary, Alberta, Canada
    73
    Default Using LISP and/or Visual LISP to find something
    I'm trying to create a LISP file by writing Visual LISP and LISP.
    I want it to find a key in the Windows registry, and if it doesn't find it, then return nil.
    If it does find it, change the key.
    Here is what I have so far, and it works. My probilem is the part that says "CADWorx 2007". I want it to find this key, and if it doesn't, then return nil, but if it does find it, use the code below to change the key. Then I want it to search for the same thing, except it says "CADWorx 2008". If it finds it, change the key (using the code below),and if it doesn't find it, then return nil.
    (defun C:test ()
    (vl-registry-write "HKEY_USERS\\S-1-5-21-1794388629-2076409663-1235820382-4565\\Software\\COADE, Inc.\\CADWorx 2007\\Plant\\Settings"
    "Configuration 17" "J:/CAD/CADWorx System Config Files/test.cfg")
    Any help is greatly appreciated.
    Last edited by Opie; 2008-02-04 at 02:37 PM. Reason: [CODE] tags added, see Moderator Note
    2007-02
    73
    Default Re: Using LISP and/or Visual LISP to find something
    Well, no one I talked to can figure it out.
    Here's what I have done now:
    (defun C:test ( / |reg-key1| |reg-key2|)
    ;_we are going to program the first key path to |reg-key1|
     (SETQ |reg-key1|
       (STRCAT "HKEY_USERS\\S-1-5-21-1794388629-2076409663-1235820382-4565\\Software\\COADE, Inc.\\CADWorx 2007\\Plant\\Settings"
       ) ;_ end of STRCAT
     ) ;_ end of setq
    ;_we are going to program the second key path to |reg-key2|
     (SETQ |reg-key2|
       (STRCAT "HKEY_USERS\\S-1-5-21-1794388629-2076409663-1235820382-4565\\Software\\COADE, Inc.\\CADWorx 2008\\Plant\\Settings"
       ) ;_ end of STRCAT
     ) ;_ end of setq
    ;_we are going to insert |reg-key1| into Windows' registry
     (vl-registry-write |reg-key1|
       "Configuration 17" "J:/CAD/CADWorx System Config Files/EnCana.cfg"
     ) ;_writes variable to the set registry key
    ;_we are going to insert |reg-key2| into Windows' registry
     (vl-registry-write |reg-key2|
     (princ)
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Something like this doesn't work?
    (defun C:test ()
      (defun reg_updt (target)
      (if
        (null
         (vl-registry-read
                 (strcat "HKEY_USERS\\S-1-5-21-1794388629-2076409663-1235820382-4565\\Software\\COADE, Inc.\\"
                         target  "\\Plant\\Settings")))
         nil
         (vl-registry-write (strcat "HKEY_USERS\\S-1-5-21-1794388629-2076409663-1235820382-4565\\Software\\COADE, Inc.\\"
      (setq result1 (reg_updt "CADWorx 2007"))
      (setq result2 (reg_updt "CADWorx 2008"))
      (princ)
  1. visual lisp editor should be like visual studio
    Last Post: 2011-11-17, 05:33 PM
  2. Programacion en Lisp y Visual Lisp
    By ralmavar in forum AutoCAD General
    Last Post: 2009-06-15, 01:52 PM
  3. Visual LISP vs VBA
    By lxpichet in forum AutoCAD Customization
    Last Post: 2009-04-07, 10:56 PM
  4. Visual LISP: If and then?
    By mikelf in forum AutoLISP
    Last Post: 2008-04-17, 10:46 PM
