Thread: Autocad Installation HUGE problem
    2008-02
    14
    Default Autocad Installation HUGE problem
    Dear Friends,
    please help to solve a problem appearing while installating AutoCAD 2008 LT!
    DWFViewer cant be installed and as a result Autocad cant be installed too.
    in the attachment couple of photos with errors and error messages are below.
    please help me!
    2008-02
    14
    Default Re: Autocad Installation HUGE problem
    also here is a message error content:
    6,396
    Windows MSI lists error code 1639 as "incorrect command line argument". That's probably not much help, but its all I can give you. Autodesk doesn't list the problem in their knowledge base.
    You might try seeing if there is an option in the setup not to install the viewer. Then after LT installs, you could go to Control Panel>Programs and try to add the viewer.
    You may need to contact your reseller for technical support.
    2008-02
    14
    thank you everybody who participate!
    i solve a problem,
    when you registering you program dont use " " in the name of company!
    have a nice day!
  1. 2004: File got HUGE and HUGE-ER - Design Center to Blame?
    By fkellogg in forum AutoCAD General
    Last Post: 2012-05-02, 01:33 PM
  2. huge problem intersection
    By shafiqsaidee492163 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-02-21, 11:02 AM
  3. problem with CAD link - it shows up HUGE!!!
    Last Post: 2009-09-17, 06:01 PM
  4. Replies: 3
    Last Post: 2008-10-01, 08:43 AM
  5. Replies: 5
    Last Post: 2006-03-10, 03:35 PM
