Results 1 to 10 of 10
Thread: 3DS MAX Huey P Long Bridge
    2007-08
    Denver, CO
    334
    Default 3DS MAX Huey P Long Bridge
    I thought I ought to join in the fray. This rendering is of the Huey P Long Bridge retro-fit in New Orleans. The old (current) configuration has two 10' lanes with no shoulder. Apparently this is now under construction. We (Brian Peterson and myself) ended up doing several renderings and an animation that is up on their site: http://www.timedla.com/bridge/long/overview/
    The file started in MR and then we finished it in V-Ray. The steelwork is a primarily opacity maps. I'd love to throw are new car library in this. The old LP3D just don't cut it anymore...
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    Default Re: 3DS MAX Huey P Long Bridge
    Great image!
    2007-08
    Denver, CO
    334
    Smile Re: 3DS MAX Huey P Long Bridge
    Quote Originally Posted by dellis View Post
    Great image!
    Thanks, Dwayne. It was certainly a bugger to build. I only had PDFs of the "as-builts" available. A good challenge, for sure.
    2007-06
    Alaska
    31
    I like it. That looks like a whole lot of work. I think that the cars are fine for the picture.
    Craig
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    A great example of opacity maps put to good use! Thanks for sharing.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    I could stop if I wanted to rmejia's Avatar
    2006-10
    Puerto Rico
    432
    Thumbs up Re: 3DS MAX Huey P Long Bridge
    I checked out the animation, wow, was everything 3d models? Must have taken a while to do, came out great, nice music too.
    2007-08
    Denver, CO
    334
    Quote Originally Posted by rmejia View Post
    Yes, everything is modeled. This was our first use of v-ray meshes for the trees. Somehow the 3D trees just look better than the opacity/plane trees.
    It was a project that a few of us worked on for a few months. The first version (just the bridge and some of the approaches) we used MR, and then converted the file over to v-ray. The main reason for the switch in renderers was to reduce the render times. MR=1hour/frame V-Ray=10min/frame. If it was a short animation, we probably would have kept it in MR. But with that many frames, we are talking about "days" difference in completing, even with the render farm.
    Português - Programação Moderator Filipe Francisco's Avatar
    2001-12
    * PORTUGAL * Sintra *
    859
    Nice Work, Good Job
    Cheers
    2006-10
    Puerto Rico
    432
    Quote Originally Posted by loydg View Post
    I use VRay also, and the VRay proxies are something I could not live with ought. Every new version of Max (Viz) I test out Mental Ray, but always end up going back to VRay.
    2007-08
    Denver, CO
    334
    I have to admit that I'm impressed with the new MR in 2008. It has Proxy objects similar to v-ray's v-ray meshes, but these support animation. So in essence, you could loop animate your trees (wind) and then instance them. Just think of the possibilities...
  1. 2013 distorted bridge
    By pelboat354433 in forum Robot Structural Analysis
    Last Post: 2013-05-17, 02:04 PM
  2. How do you model a bridge?
    By Revitaoist in forum Revit - Conceptual Design Tools
    Last Post: 2011-10-25, 08:07 PM
  3. Bridge Construction
    By loydg in forum DV - Gallery
    Last Post: 2010-10-25, 03:34 AM
  4. Long, long list of Keywords
    By rjcrowther in forum Revit - API
    Last Post: 2007-12-10, 08:22 AM
  5. 3D Bridge
    By SRBalliet in forum AutoCAD Gallery
    Last Post: 2006-08-28, 11:48 AM
