Thread: Level Filter?
    Default Level Filter?
    Is there any way to "Hide" an entire level? For instance, if I had a complete 2-story home, and then wanted to Turn off the Roof and second floor, to be able to view just the first floor. The only reason i really need to do this is just for Demonstration purposes. Once i have a plan done, i sit down with the builder and do a "Walk Thru" of the plan. It would be nice to turn off specific levels quickly to show the overall layout, without just placing multiple camera views.
    Thanks for any advice
    2003-04
    Chino, CA
    4,756
    Default Re: Level Filter?
    use a 3D section box in a 3D view to "cut" a building any way that you would like. Cut off the roof and top floor, or a side wall, or both.
    100 Club steve.70285's Avatar
    2004-06
    BC, Canada
    150
    You could also use phasing; this would allow you to build the project during a demonstration simply by advancing the project through phases. I like Scott's method better though, just because it’s quick and not much setup.
    Moderator JamesVan's Avatar
    2016-01
    New York, NY
    625
    An easy way to implement Scott's method is to open a 3D view, then select View-Orient-To Other View... then pick the plan view of choice. It will automatically create the section box according to the view range of the selected plan.
  1. 2014: Filter - create Filter by Reference Level.
    By swapr78 in forum Revit MEP - General
    Last Post: 2015-01-17, 11:13 PM
  2. Filter by Level
    Last Post: 2014-10-30, 07:10 PM
  3. 2012: Filter for Level ...is below not working
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2013-10-04, 07:09 PM
  4. Pipe Filter by level offset - Reference Level Offset
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-04-02, 04:05 AM
  5. Is there a way to filter by level?
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2006-10-10, 08:59 PM
