Results 1 to 10 of 10
Thread: Steps
    2007-09
    Mumbai
    44
    Cool Steps
    Does anyone have or knows how to write a routine for draw 'steps' in drawing in plan, section and elevation.Any solution for this will be appreciated. Thankyou.
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Default Re: Steps
    2007-09
    Mumbai
    44
    Cool Re: Steps
    Hi CAB,
    Thank you for your quick replay. But I am sorry to say that I can't open that link which you send to me. Hope that you will revert back soon. Thank you again.
    2016-01
    Brandon, Florida
    687
    Default Re: Steps
    Sorry, I can't figure out how to post a link to a Search, but if you search on stairs you will find some routines.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,449
    Default Re: Steps
    Quote Originally Posted by CAB2k View Post
    CAB,
    Will this help?
    To link to an actual search instead of a cached search add "do=process" to the end of the Search URL link found in the top left of the Search Results page. Be warned, there is a set of brackets "[]" after "forumchoice" within the URL that will need to possibly be replaced with & #91;& #93; without the spaces.
    2016-01
    Brandon, Florida
    687
    Default Re: Steps
    Well I get this as the URL
    http://forums.augi.com/search.php?searchid=1572272
    and if I change to this
    http://forums.augi.com/search.php?se...272&do=process
    it doesn't work?
    2002-01
    jUSt Here (a lot)
    8,449
    Default Re: Steps
    it doesn't work?
    You can't use searchid links. That is something the forum software creates to cache (temporarily) the searches made throughout the day.
    Edit:
    To add further to my previous explanation ...
    Check your second image on your previous post. You should see along the top line the following text
    Search: Key Word(s): stairs ; Forum: AutoLISP and child forums
    By right-clicking the word "Search" on that line, you should be able to copy this link (or shortcut). This is the link you will need to use to post a direct link to a search on those words.
    You cannot use the URL in your browser's address bar. That will go to the cached search page that expires. I do not know how long the search is live.
    2016-01
    Brandon, Florida
    687
    Default Re: Steps
    That worked.
    Thanks Opie.
    2002-02
    Kansas
    487
    Default Re: Steps
    I have a vba program that draw elevation for stairs.
    it make a block of the elevation view of the stairs.
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
    2002-01
    jUSt Here (a lot)
    8,449
    Default Re: Steps
    That worked.
    Thanks Opie.
    Glad I could help. I know it is a pain, though.
  1. 4 steps
    By sergiu_ciuhnenco688457 in forum AutoLISP
    Last Post: 2015-01-09, 12:19 PM
  2. Theatre steps
    By Terry Richardson in forum BIM Management - General
    Last Post: 2012-10-13, 11:53 PM
  3. Auditorium steps
    By march in forum Revit Architecture - General
    Last Post: 2011-02-01, 05:03 AM
  4. 3DS Max Steps
    By craigbennett in forum DV - Gallery
    Last Post: 2008-02-04, 08:14 PM
  5. 12 Steps
    By mead1 in forum New Forum Users (Non technical)
    Last Post: 2005-10-18, 01:00 PM
