Thread: Edit Group bug
    2004-05
    7
    Default Edit Group bug
    Haven't mentioned this to support, so I'm not posting it in "known problems". Has anyone noticed after you use the tape measure tool while editing a group, you can no longer open the property sheet on a group member? Only workaround I see is to Finish Group and then edit it again. *sigh*
    Mark
    2003-05
    5,153
    Default Re: Edit Group bug
    Yes, I've seen that happen. Not a big problem, but a bit annoying.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
  1. How do you close a Group after you edit it???
    By JH75 in forum Revit Structure - General
    Last Post: 2018-10-16, 02:48 PM
  2. Group Edit Panel GONE
    By Doug in forum Revit Architecture - General
    Last Post: 2012-02-02, 09:12 PM
  3. Group Edit Problem
    By Craig_L in forum Revit Structure - General
    Last Post: 2011-03-07, 10:32 PM
  4. Edit Group
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-08-26, 03:38 PM
  5. Edit -> Group: How to reload it now?
    By scowsert in forum Revit Architecture - General
    Last Post: 2008-12-17, 07:18 PM
