So I am trying to setup a block which will reside in a title block that is inserted with sheet sets that a user can click on or however it should be accessed and choose the engineers stamp which should be shown in the title block. What I have done is created one block with all of the engineers stamps in it and was trying the lookup parameters and such, but am not having any luck. AM a bit limited on time for this one and was hoping someone could take a look and maybe set it up and then explain what I could/should of done? Am I making it harder than it is? I will attach the block that I am referring to. It is in 2007 format. I am using 2008. Thanks for any input and help you can assist with!
