http://pressreleases.autodesk.com/in...383%3C%2Ftd%3E
If you have been loving VIZ, look out - this will be a big change!
Also more info can be found here:
http://www.worldpressdays08.com/page...roducts&sub1=1
I work for a reseller and didn't know about this until last week.
So my question is: am I correct in thinking that the new Autodesk 3ds Max Design 2009 product will cost the same as max? Thus eliminating a competent product at a fair price and replacing it with a far more expensive version which will be more than a lot of people need?
I see this as a way to make more money, not give us more features. Are they going to eliminate ACAD LT too?
Sorry for the rant. I just don't appreciate this as a "we're doing this for the customer" move.
All that said, i actually do prefer max over viz, but only because most of the plugins out there that give better functionality than the app ships with are written for max, not viz, and while some work as long as you can figure out what versions are comparable, some do not.
Feature wise, there really aren't any max features that I would NEED to have for arch-vis. I never filled out a survey on whether I would rather use Max, and I find it hard to believe that 90% of viz customers have every really tried Max or really know why they would rather use max.
I'll tell you what would really "exceed my expectations". They give me this new max design 09 for the same subscription cost as VIZ and simply cross-grade my subscription to max with no additional fees. THAT would prove that this is about customer satisfaction and not about lining their pockets at the borg.
A valid complaint and the following is not meant to try and minimize it or help you justify Autodesk's decision. Pricing is discussed in this PDF which is from the link I posted earlier in this thread. As a humble suggestion, possibly take a look at the documents that have been released prior to Auto-bashing Autodesk. The cost to cross grade from VIZ to 3ds MAX Design is dirt cheap and gets you into a higher end product.
Some things to consider about this:
Again, the above is to try and help those faced with VIZ being phased out see some of the factors they might not originally have thought of. Hope this helps.
- VIZ and MAX have different binaries, which means twice the amount of work is needed to maintain VIZ.
- 3ds MAX and 3ds MAX Design are of the same binary which means they can reduce the amount of resources needed to maintain VIZ and focus on the 2 flavors of MAX.
- The new feature list in 3ds MAX Design is impressive - especially for those who are in the Architectural field.
- Existing VIZ subscription customers will have access to a new plugin for VIZ - Pro-Booleans - which was previously only available for 3ds MAX.
- Autodesk has a responsibility to its share holders to remain a profitable company, so part of this may be about "money" but at least they are focusing their efforts on one product to address the needs of the Architectural field. In the past, 3ds MAX was strictly for game development. The Architectural field has really helped push the evolution of MAX into an entirely different field and Autodesk is trying to address this use of MAX in the most efficient way possible. Would you provide some customers' a service that was efficient and others a service that you lost money on?
From the press release:
So... even though they're the same price, why wouldn't everyone get Max and ditch Design? It's the same price for the same product (plus you get the SDK).3ds Max Design 2009 includes all features offered in Autodesk 3ds Max 2009, with the exception of the software development toolkit (SDK).
