Thread: Convert to pdf
    2003-05
    26
    Default Convert to pdf
    Not sure if anyone else has run into this problem. I am trying to create a pdf from my drawing and I have a Raster Image in the background. When I create the pdf it only prints out part of the Raster Image but includes everything else. Just wondering if anyone knew of a setting I'm missing that is maybe limiting the size of my pdf, hence cutting off part of my Raster Image.
    9,805
    Default Re: Convert to pdf
    What PDF driver are you using?
    100 Club jason.combs's Avatar
    2005-08
    St. Louis, MO
    173
    Give consideration to how much memory your PC has. We have had problems with large aerial image underlays with our plans. We ended up going to 4GB of RAM and XP Pro.
    9,805
    Exclamation Re: Convert to pdf
    Quote Originally Posted by jason.combs View Post
    Are you using the 3GB startup switch?
    2005-08
    St. Louis, MO
    173
    Yes. We use Acroplot Pro.
  1. 2010: convert dgn to dwg
    By mkr_trash in forum AutoCAD General
    Last Post: 2012-10-08, 12:24 PM
  2. Convert a PDF into a DWG
    By huuthu_nguyen82544 in forum AutoCAD LT - General
    Last Post: 2006-08-18, 01:02 AM
  3. Convert DWG to PCX
    By mreynolds9 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-31, 08:52 AM
  4. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
