Results 1 to 6 of 6
Thread: Redefining Blocks
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    Default Redefining Blocks
    Anyone out there had a problem when trying to redefine a block and getting and invalid message. It appears that the block is referencing itself and so will not allow the function. Is there anyway to get around this problem as I need to be able to update on mass several hundred title blocks?
    2004-08
    Iron Station, NC
    3,198
    Default Re: Redefining Blocks
    open up the block that you are trying to redefine and purge it to remove its reference to itself
    2005-04
    RAT HALL
    298
    Quote Originally Posted by ccowgill View Post
    I tried that but to no affect on it. You can see the problem with it
    2004-08
    Iron Station, NC
    3,198
    could you post the block on line for others to take a look at it?
    2003-10
    706
    If the block with the same name as the file won't purge, it means there's an instance of that block inside the file. The easiest thing I've found to do is to RENAME the block inside the block file so its name inside the file is different from the actual filename. Works every time.
    (That's a hard sentence to type )
    2005-04
    RAT HALL
    298
    it worked, but I'm afraid I cheated in the end and burst all of them as time was critcal and the client wouldn't realise anyway. But thanks folks for all your help
  1. redefining mvparts blocks
    By mwalker.87963 in forum Parts Builder
    Last Post: 2010-09-17, 02:11 AM
  2. Redefining old Blocks to new Dynamic Blocks
    By dgriessmann.86073 in forum AutoCAD General
    Last Post: 2006-10-31, 09:41 PM
  3. Redefining your Dynamic Blocks
    By whdjr in forum AutoCAD Tips & Tricks
    Last Post: 2006-06-27, 02:51 PM
  4. Dynamic Blocks Not Redefining
    By Rico in forum Dynamic Blocks - Technical
    Last Post: 2006-02-07, 07:50 PM
  5. redefining blocks
    By rwbaker in forum AutoCAD General
    Last Post: 2005-09-27, 09:31 PM
