Thread: Invalid argument scale in setting standard scale property
    2006-10
    12
    Default Invalid argument scale in setting standard scale property
    This is a new one for me. After choosing a viewport and going to the properties tool pallette to select a scale I find all of the usual scales but also multipule repeats of the usual scales with the word "xref" added many times to each scale choice. I then choose the scale I want (without the "xref's" added) and I get the error dialog box with the statement "Invalid argument scale in setting standard scale property". That means I can not set the scale of the viewport. If you have experienced this I would like to know where the "xref's" come from and how to get rid of them.
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: Invalid argument scale in setting standard scale property
    This is a known problem, there's been some work on this ... but it still sometimes crops up its ugly head. See this link: http://rkmcswain.blogspot.com/2007/1...cale-list.html
    2006-10
    12
    Thank you very much. Now to use it on all the drawings.
    2008-07
    2
    You can set the annotative scale, which will cause the standard scale to change to match.
    I fight this problem every day. If it changes standard scale on you, like when 3D clipping, then you must change the annotative scale to another scale then back to the scale you want.
    I don't understand how Autodesk, instead of fixing viewport problems, keeps introducing more.
    Earth
    9,804
    Quote Originally Posted by irneb View Post
    This is a known problem, there's been some work on this ... but it still sometimes crops up its ugly head. See this link:......
    Although the above link is still good for now, here is an updated URL:
    http://cadpanacea.com/node/97
    R.K. McSwain | CAD Panacea |
  1. Annotation & Standard Scale
    By mockdeep in forum AutoCAD Annotation
    Last Post: 2008-02-05, 03:51 AM
  2. AutoCAD LT Plotting message - invalid scale factor
    By jenniferk in forum AutoCAD LT - General
    Last Post: 2006-05-18, 07:11 AM
  3. default scale factor is invalid
    By CADMama in forum AutoCAD General
    Last Post: 2006-03-02, 09:54 PM
