Results 1 to 10 of 17
Thread: Speed things up...
    2016-01
    I come from a land downunder...
    230
    Default Speed things up...
    A couple of things I have recently discovered:
    You know how SLOW it is, panning around a floor plan (by holding the mouse button down and dragging). It's so bad that the image completely disappears, and re-appears 10 seconds later, hopefully in the spot where you want it. If not you haver to go through the same tedious precess again.
    Well, this whole "pan-by-dragging" process appears to be much much quicker in a 3D view.
    So here's the tip:
    Go to you 3D view, then go to the dynamic view (F8) and orientate the view to top. It effectivly gives you a plan view. Now you can pan around a plan much quicker. Bingo!
    And the other tip, if you orientate the 3d view to an elevation, you can effectivly draw 3D pipes and ducts from a section view, something you can't do from a normal section.
    Hope it helps....
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Re: Speed things up...
    use a coordination view also. Mechanical and electrical discipline views have to calculate hidden lines and the what not, and as such are extremely slow. I either work in a separate views (which has other advantages) or turn the disciplines onto electrical and mechanical before I need to print.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2007-08
    Chicago
    40
    Indeed, I am very happy about the addition of the cube, in the up coming release of mep 2009. If you have not seen or heard about this check out insidethesystem.com - Kyle B. has posted a video that got my blood pumping a little fast, it will save alot of time. Now if only I can convince Architects not to give me a 300 mb model that is useless. uh oh haha.
    2016-01
    230
    Quote Originally Posted by Mcgregage View Post
    www.insidethesystem.com takes me nowhere.
    Is that link correct?
    2003-04
    Chino, CA
    4,756
    2016-01
    230
    Quote Originally Posted by Scott Davis View Post
    Hmmm! That's better!
    Thanks.....
    2005-05
    Lakewood, CO
    28
    Another thing that helps is unloading uneeded worksets. I've gotten into a habit of unloading all the electrical worksets except maybe lighting to streamline opening and saving. You just have to load them back in before you print if there are electrical items on your plans.
    Also, remove uneeded sections, plans and 3D views as they can really bog things down.
    2007-12
    Can we discuss Computer Specs?
    I'm working on a machine with a:
    Pentium D 3.25GHz
    3.25Gb RAM
    ATI X300.
    I'm finding Revit almost impossible to use, panning and zooming is a nightmare. Every duct connection I make is a 10 second Wait. Progress is painfully slow.I've had a few crashes while trying to make a connection or when changing the size of an already connected duct. I'm working with a model that is only about 10mb, a small two story building.
    I realize the Video Card needs an upgrade (ordered an ATI Fire GL 3700), but is it really the remedy to my issues? What are you all using and what is your performance like in Zooming, panning, making connections and just general use.
    Thanks for any help.
    2016-01
    230
    Quote Originally Posted by Stevelessoway View Post
    Pentium D 3.25GHz
    3.25Gb RAM
    ATI X300.
    Intel(R) Core 2 CPU
    6700 @ 2.66GHz
    2.66GHz, 3.37 GB of RAM
    (Whatever all that means)
    And yes, it is painfully slow, and yes, it crashes from time to time.
    Luckily though, it doesn't seem to slow down Internet Explorer, so for the most part I find myself surfing the net while waiting for the screen to regenerate.
    Or you could try bringing a good book to work, perhaps?
    2007-03
    890
    Does anyone know if Vista x64 speeds things up a bit? (dare I ask)
    Baltimore, MD
  1. I want to relinquish things automatically just as I own things automatically
    Last Post: 2012-06-25, 06:44 PM
  2. Games' speed vs Revit Speed
    By rudolfesterhuyse in forum Revit Architecture - General
    Last Post: 2010-04-09, 02:23 PM
  3. Replies: 1
    Last Post: 2010-01-29, 08:48 AM
  4. P4 HT & speed?
    By truevis in forum Revit - Rendering
    Last Post: 2006-09-20, 08:02 PM
